[GRASSLIST:5188] Re: newbie question
Eric G. Miller
egm2 at jps.net
Sun Dec 8 21:30:11 EST 2002
On Sun, Dec 08, 2002 at 11:42:12PM +0000, Glynn Clements wrote:
> If the filesystem was mounted in "text" mode, Cygwin will attempt to
> perform LF/CRLF translation, which will corrupt the files; in this
> case, you would need to start again, as any files which had been
> generated would already be corrupt.
Hmm, does Cygwin open all files opened via open() in binary mode? I
should think so. However, it seems we should add the "b" to all the
fdopen() calls in src/libes/gis/open.c. On *nix systems it makes
no difference, but it might make the difference on other systems.
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
