[GRASSLIST:5215] Re: netCDF to raster
Paul Hasenohr phasenohr at cls.fr
Wed Dec 11 09:16:37 EST 2002
Hello Vidya,
I know two ways to import netCDF files into GRASS.
1) You install R and you use R inside GRASS. R is able to read netCDF
files, so you can export your variable in GRASS. I used this method six
months ago and it worked fine.
2) An other option
You convert your netCDF file to an ascii file readable with the r.in.ascii
command.
I prefer this option because it is less system resources consuming.
I made a shell script to convert netCDF file into GRASS raster ascii file
but I use netCDF tools developed by my company and there are
not  publically available. However, if you are interested in, I can send it
to you and I believe that it is easily portable with the nco tools
(http://nco.sourceforge.net, have a look at ncks)
HTH
Paul
At 01:14 11/12/2002 -0800, vidya kotamraju wrote:
>Hi all,
>I am a newbie at GISs and GRASS.
>I am using GRASS 5.0.0 and need to convert a netCDF
>format dataset to the raster format in GRASS.I suppose
>one needs to gmake r.stage3 which doesnt come with
>GRASS 5.0.0
>How do i go about this process ? Do i need to download
>some additional files ?
>And how can i convert the raster form back to netCDF ?
>any pointers ?
>Regards,
>Vidya Kotamraju
>__________________________________________________
>Do you Yahoo!?
>Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
>http://mailplus.yahoo.com
