[GRASSLIST:5216] Re: mapcalc??
sjors jkwast at freeler.nl
Wed Dec 11 10:42:37 EST 2002
Eric G. Miller wrote:
>On Tue, Dec 10, 2002 at 05:52:23PM +0100, sjors wrote:
>>Hi,
>>I've got a rastermap with categories 1-84, not labelled. Now if I use
>>mapcalc to find everything smaller or equal than 45 it's oke, only
>>categories 1 thru 45 are there. Now if I want everything bigger than 45
>>it produces a map with all categories. Is this a bug? BTW I'm using
>>grass5pre3.
>Please post what you fed r.mapcalc that produced these results.
Hi Eric,
This what I did in mapcalc:
growborder12 = if(growborder4,\
            if(growborder4>=45 && x()<=1899.381324 &&
x()>=1899.381324+((731.532598-1899.381324)/(sqrt((731.532598-1899.381324)^2+(2571.477126-2465.314883)^2)))*1200,1,0))
result is cat 0-77 because of the X coordinates. Need 45-77.
Well I've worked around by substracting >= 45 cat(0-77) with <=45 (cat
0-45).
Hope it'll give insight,
greetings Sjors
