[GRASSLIST:5232] Re: netCDF to raster
vidya kotamraju vidyakr at darya.nio.org
Mon Dec 16 18:40:03 EST 2002
Hi paul,
I guess i will be comfortable with the 2nd option.
Could u pls send me the script if it is possible ?
Also, after converting the netCDF file to the raster map form,
I need to be able to modify the point values of the map so as to modify
the variables of the netCDF file that i shall reconvert the raster map to.
Like r.support is used to modify the header information how can i actually
go about modifying the variables of the netCDF by means of its
corresponding raster map ?
Thanx in advance.
Vidya Kotamraju
--- Paul Hasenohr <phasenohr at cls.fr> wrote:
> Hello Vidya,
> I know two ways to import netCDF files into GRASS.
> 1) You install R and you use R inside GRASS. R is
> able to read netCDF
> files, so you can export your variable in GRASS. I
> used this method six
> months ago and it worked fine.
> 2) An other option
> You convert your netCDF file to an ascii file
> readable with the r.in.ascii
> command.
> I prefer this option because it is less system
> resources consuming.
> I made a shell script to convert netCDF file into
> GRASS raster ascii file
> but I use netCDF tools developed by my company and
> there are
> not  publically available. However, if you are
> interested in, I can send it
> to you and I believe that it is easily portable with
> the nco tools
> (http://nco.sourceforge.net, have a look at ncks)
> HTH
> Paul
