[GRASSLIST:5247] Re: install-grass51 No rule to make target `bitmap.c'
Glynn Clements
glynn.clements at virgin.net
Thu Dec 26 16:27:46 EST 2002
Nico Hardebol wrote:
> While doing - grass 5.1 Make - I get an error due to No rule to make target
> bitmap.c'.
> I use grass51src_cvs_snapshot_exp_2002_12_2 and
> grass50src_cvs_snapshot_exp_2002_12_20, install the software under Suse linux
> 7.2
> and do:
> CFLAGS="-g -Wall" ./configure --with-grass50=../grass50_exp_2002_12_20
1. GRASS 5.1 is experimental; all comments should go to the developers'
list at grass5 at grass.itc.it.
2. The argument to --with-grass50= should be an *absolute* path, not a
relative path; it has to be valid from any directory, not just the
top-level directory.
Glynn Clements <glynn.clements at virgin.net>
