[GRASSLIST:5255] Re: Raster map not being displayed
Eric G. Miller
egm2 at jps.net
Tue Dec 31 07:06:56 EST 2002
On Tue, Dec 31, 2002 at 04:15:16PM +0530, Vidya Kotamraju wrote:
> Hi all,
> I am converting an ascii file into raster form by making use of r.in.ascii
> input=globedem.ascii output=globedem title=try mult=5.0
> The ascii file goes like this :
[snip]
> With each row being of above format.
> On running this command, the raster file along with the support files is
> created.However on running d.rast globedem
> a blank screen is displayed with white bg.
The usual cause is failure to update the region (run g.region
rast=<foo>).
> Also there isnt a ascii to raster converter option in the GUI.
Hmm, an oversight I guess (just needs a line in menu.tcl to source
the module entry).
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
