[GRASSLIST:3150] d.colormode float
DeanRNet6 at netscape.net
Fri Feb 15 20:55:12 EST 2002
Howdy,
Just installed GRASS. I'm a newboot, forgive me. I'm pretty darn good
GISer though.
So, I'm using MacOSX 10.1.2 because I need a break from Windoze, VB and
ESRI on occasion. I'm having trouble with d.colormode float.
When I type it at the command line
>GRASS 5.0.0pre3 > d.colormode float
I get the following message:
>WARNING: Color_table_float: not available on this device
>Sorry, floating color table not available on this device
So here I am following the tutorial and it tells me this:
Display the satellite image again.
>Commands :
>d.mon select=x0
>d.rast image
Which I do.
>Discussion The image should consist of approximately 8 shades of grey
- enough >to identify most of the features of the study area. As GRASS
is capable of >displaying up to 240 colours on an most workstations, why
are there only 8 grey >shades making up this image? GRASS has a fixed
palette of colours all of which >can be displayed simultaneously. Since
an image can consist of any range of >colours, only a few can be
reserved for grey scales. GRASS simply matches each >raster cell value
to the nearest available colour.
>We can produce an improved image by abandoning GRASS' fixed palette
and >dedicating most of the range of colours to one image.
>Make sure the pointer is resting over the graphics window x0.
What exactly does this mean. If my cursor is over the window x0, then I
can't type 'Enter' and have the terminal window respond.
>Commands :
>d.colormode float
>d.rast image
>Discussion You should see an improved satellite image of the study
area. The >majority of the workstation's colours have now been allocated
to grey values in >this one window. When using this floating colour
table, GRASS allocates the >correct colours to the window on which the
pointer is resting.
So I type d.colormode float and get the error I mentioned before.
Anybody have any insight on this?
Thank you,
Dean
