[GRASSLIST:3178] help - creating a new region
uleopold
uleopold at science.uva.nl
Thu Feb 21 03:47:13 EST 2002
Dear list,
I guess this is a very simple question but I cannot find exact help in the
manuals etc..
I try to create my region settings for the Netherlands. Here a
stereographic projection with the bessel elipsoid is used.
When it comes to the following questions in GRASS5 I do not exactly know
what to fil in:
- Enter Central Parallel [lat_0] (0) : 52.15616055 deg ??
- Enter Latitude of True Scale [lat_ts] (0) : ??
- Enter Central Meridian [lon_0] (20E) : 5.38763889 deg ??
- Enter Scale Factor at the Central Meridian [k_0] [1.0000000000]:
0.999907900838 ??
- Enter plural form of units [meters]: meters (that's clear)
Thanks for you attention.
Ulrich
Geodetic Datum Transformation Parameters
>From NIMA 8350.2 4 july 1997 and HTW
Bursa-Wolf Transformatie Parameters between Netherlands RD-system
(stereographic) and WGS 84
Shift: X +565.040 m Rotation X 0.00011372 deg
Y +49.910 m Y -0.00009992 deg
Z +465.840 m Z 0.00051903 deg
Scale Difference: 0.0000040774
Netherlands RD-system (STEREOGRAPHIC):
System Parameters:
Longitude of origin: 5.38763889 deg
Latitude of origin: 52.15616055 deg
False Easting: 155000.000 m
False Northing: 463000.000 m
Scale reduction factor: 0.999907900838
Ellipsoid Parameters: Bessel 1841
Equatorial Radius: 6377397.155 m
Polar Radius: 6356078.963 m
Eccentricity: 0.0816968312225275
Flattening: 0.0033427731821748
Flattening inverse: 299.1528128
Spherical Model: Gaussian
Radius 6382644.571 m
Latitude 52.15616055 deg
WGS 84:
System Parameters: p.e. Zone 31
Longitude of origin 3.000 deg
Latitude of origin: 0.000 deg
False Easting: 500000.000 m
False Northing 0.000 m
Scale reduction factor 0.9996
Ellipsoid Parameters: WGS 84
Equatorial Radius: 6378137.000 m
Polar Radius: 6378137.000 m
Eccentricity: 0.0818191908426215
Flattening: 0.00335281066474746
Flattening inverse: 298.257223563
Radius 6356752.314 m
Latitude 0.000 deg
Testdata
RD/bessel input UTM/wgs84 output
155000.00 463000.00 663303.930 5780984.291 zone 31
176543.00 465432.00 684756.535 5784124.081 zone 31
247053.00 535311.00 348445.554 5852083.900 zone 32
Ulrich Leopold MSc.
Department of Physical Geography
Institute for Biodiversity and Ecosystem Dynamics
Faculty of Science
University of Amsterdam
Nieuwe Achtergracht 166
NL-1018WV Amsterdam
Phone: +31-(0)20-525-7456 (7451 Secretary)
Fax: +31-(0)20-525-7431
Email: uleopold at science.uva.nl
http://www.frw.uva.nl/soil/Welcome.html
Check us also out at:
Netherlands Centre for Geo-ecological Research
http://www.frw.uva.nl/icg
