[GRASSLIST:3198] Re: PNG on macosX/grass5pre3
Glynn Clements
glynn.clements at virgin.net
Sat Feb 23 00:29:06 EST 2002
Wouter Buytaert wrote:
> I recently installed all the necessary libraries to run the PNGdriver on
> my macOS X/grass5pre3 system. There is a PNG file in my
> /usr/local/grass/drivers but the driver isn't listed in the d.mon.
> ("There is no such driver").
There should also be an entry in etc/monitorcap:
PNG:driver/PNG:Create PNG Map: \
dev/fifo.16a dev/fifo.16b \
::any terminal
Glynn Clements <glynn.clements at virgin.net>
