[GRASSLIST:3234] Re: frame problem
Glynn Clements
glynn.clements at virgin.net
Tue Feb 26 16:29:34 EST 2002
orkun wrote:
> I ran into a problem with d.frame.
> after setting up a frame in a grass-monitor,
> i change the size of grass-monitor, the frame is getting lost.
> What can I do to solve the problem?
This should be fixed in the current CVS version.
For older versions of XDRIVER, the only solution is to avoid resizing
the monitor interactively.
Glynn Clements <glynn.clements at virgin.net>
