[GRASSLIST:3246] Re: help with theory of map projections
Glynn Clements
glynn.clements at virgin.net
Wed Feb 27 11:04:45 EST 2002
chris2 wrote:
> I have been trying to learn the theory behind map projections from the
> book "Map Projections, A reference Manual" by Bugayevskiy and Snyder.
> I am stuck on page 2 in Chapter 1, if you can believe it, where they
> take an ellipsoid of revolution, and a point on its surface at
> latitude phi, and mention that the radius of curvature of the meridian
> through the point is:
> M= a*(1-e^2) / [(1-e^2*sin(phi)^2)^(3/2)]
> Where e, a, and b are the eccentricity and semimajor and semiminor
> axes of the ellipse of revolution.
> I set out to verify this formula as a way of reviewing my vector
> caclulus and getting started with the book.
> I used the following parameterization of the ellipse:
> x = a*cos(t)
> y = b*sin(t)
> My t, by the way, is equivalent to their phi, I am pretty sure. That
> is, t is the angle between a normal line to the ellipse through the
> given point, and the x-axis.
I don't think so. Differentiating gives:
dx/dt = -a*sin(t)
dy/dt = b*cos(t)
=> dy/dx = -(b/a).cot(t) [cot(x) = 1/tan(x) = cos(x)/sin(x)]
=> normal grad. = (a/b).tan(t) [normal grad. * tangent grad. = -1]
Clearly, the normal gradient is tan(phi), by the definition of phi.
If it's any consolation, I also got stuck right at the beginning of
that book. My conclusion is that geodetic longitude sucks from a
coordinate geometry perspective.
Glynn Clements <glynn.clements at virgin.net>
