[GRASSLIST:3011] Re: Vector manipulation
M Lennert
fa1079 at qmul.ac.uk
Mon Jan 28 10:44:47 EST 2002
Emmanuel Poizot <poizot at cnam.fr> wrote:
> Hi,
> I'm a newbie in GRASS world.
> It sems that GRASS better manipulate raster data, however
> I should like to manipulate vector data, thinks that GRASS seems to do
> also.
> I've got some difficulties to find the operations that permits to
> display
> a vector with different colors for vectors that have a specific value on
> a field.
> I also have some difficulties to find informations that permits me to
> build and
> print a map with scale, legend, graticules, etc.
> Cordialement
Emmanuel,
I don't know if this would help, but I wrote a little script that allows
you to display vector areas in greyscale (sorry, no color, yet)
according to defined class boundaries. It uses the latest version of
d.area which is in Grass 5.0.0pre3. You can combine this with the
PNG driver for map output.
Usage: d.area.class map=name catfile=name
classes=boundary1[,boundary2,..]
Parameters:
map = vector map to display
catfile = variable file with 2 columns seperated by whitespace:
1=category 2=variable by which to class)
classes = class boundaries separated by comma, starting with
boundary between class 1 and 2 and ending with boundary
between class max-1 and max
example:
d.area.class map=communes catfile=ACP_scores1 classes=-
0.85421,-0.48965,-0.14563,0.35487,0.63214
This would take the file ACP_scores1 as input and display
'communes' with its areas divided into 6 classes:
1: < -0.85421
2: -0.85421 -> -0.48965
3: -0.48964 -> -0.14563
4: -0.14562 -> 0.35487
5: 0.35488 -> 0.63214
6: > 0.63215
The catfile should look like this:
catnum1 variable
catnum2 variable
catnum3 variable
etc... (can be integer or floating point variable values).
So in my example it would be
11001 -0.14568
11002 0.32287
11003 -0.24587
etc...
The script then displays each category in greyscale, first=lightest,
last =darkest. It can be used in conjunction with the PNG driver in
order to rapidly create thematic map output.
Just save the script into a file called d.area.class (or anything else
you like). Make it executable (chmod 0755 d.area.class) and run it
from within Grass.
Moritz
#*********script begin***********************
#! /bin/sh
# script d.area.class
# displays vector maps in grayscales according
to given class boundaries
# written by Moritz Lennert - 2002
# mlennert at club.worldonline.be
if test "$GISBASE" = ""; then
echo "You must be in GRASS to run this program."
exit
fi
if [ $# != 3 -o "$1" = "-h" -o "$1" = "-help" -o
"$1" = "help" ]
then
echo ""
echo "Usage: d.area.class map=name
catfile=name classes=boundary1[,boundary2,..]"
echo ""
echo "Parameters:"
echo " map = vector map to display"
echo " catfile = variable file with 2
columns seperated by whitespace: 1=category
2=variable by which to class)"
echo " classes = class boundaries separated
by comma (but no whitespaces), starting with
boundary between class max-1 and max"
echo ""
exit
fi
for i
do
case $i in
m=*|ma=*|map=*)
MAP=`echo $i |
awk -F '=' '{print $2}'` ;;
ca=*|cat=*|catf=*|catfi=*|catfil=*|catfile=*)
CATFILE=`echo
$i| awk -F '=' '{print $2}'` ;;
cl=*|cla=*|clas=*|class=*|classe=*|classes=*)
CLASSES=`echo $i
esac
done
if [ ! "$MAP" ]
then
echo
echo "No vector map name given"
echo
exit 1
fi
if [ ! "$CATFILE" ]
then
echo
echo "No variable file name given"
echo
exit 1
fi
if [ ! "$CLASSES" ]
then
echo
echo "No class boundaries given"
echo
exit 1
fi
export MAP
export CLASSES
awk '
BEGIN{
map=ENVIRON["MAP"]
#num is number of classes of which the
boundaries are put into array 'classes'
num=(split(ENVIRON["CLASSES"], classes, /,/) +1)
# create the lists of catnums for the d.area
command according to class boundaries
for(i=1;i<=num;i++) {
if(i==1){
if($2<=classes[i]) catnum[i]=catnum[i]
sprintf("%s,",$1)
}else{
if(i==num){
if($2>classes[i-1]) catnum[i]=catnum[i]
sprintf("%s,",$1)
}else{
if($2>classes[i-1] && $2 <= classes[i])
catnum[i]=catnum[i] sprintf("%s,",$1)
END{
for(i=1;i<=(num);i++){
#calculate greyshade
col=230-((230-20)/(num)*i)
#create the d.area command
syscom=sprintf("d.area map=%s linecolor=black
fillcolor=\"rgb(%i %i %i)\" catnum=", map, col,
col, col)
syscom = syscom catnum[i]
#avoid empty catnum list since this would
display entire vector file
if(length(catnum[i])>0){
print "displaying class " i
system(syscom)
} else {
printf"class number %d is empty\n", i
' $CATFILE
#************script end**************
