[GRASSLIST:3046] r.los - question
Izak Thomas Henry Deyzel izak at metsys.weathersa.co.za
Wed Jan 30 09:25:04 EST 2002
Good day,
Does anyone know if r.los takes the curvature of the earth in effect
during its calculation?
ALSO:
"DESCRIPTION
 r.los generates a raster map output in which the cells that are visible
from a user-specified observer location are marked with integer values
that represent the vertical angle (in degrees) required to see those
cells (viewshed)."
The vertical angle as in: ?
    180 deg
    ----- 90 (91 - 1 degree above horizontal?)
     0
OR ?
    0
    ----- 90 (89 - 1 degree above horizontal?)
    180
Please help.
Does any references exist to literature for the method of r.los?
Thanks.
Izz
