[GRASSLIST:4031] Re: CELL Driver won't start (5.0.0pre3)
cheg01 at attbi.com
cheg01 at attbi.com
Fri Jul 5 03:01:33 EDT 2002
The problem may be related to running on a 64 bit Sparc Ultra with binaries
made on a 32bit Sparc 20. I found that the same CELL driver works on the
machine I built on originally. I am going to try building the pre5 source
on the Ultra with GCC 3.1.
Thanks for the responses.
----- Original Message -----
To: <cheg01 at attbi.com>
Sent: Thursday, July 04, 2002 11:17 PM
Subject: Re: [GRASSLIST:4029] CELL Driver won't start (5.0.0pre3)
> Hi...there
> Please check all the fifos are created in appropriate directory
first...is
> so...check the command "CELL" is present or not also check the size of
> CELL....if not create fifos again..
> bipin
> From: <cheg01 at attbi.com>
> To: <grasslist at baylor.edu>
> Sent: Friday, July 05, 2002 10:22 AM
> Subject: [GRASSLIST:4029] CELL Driver won't start (5.0.0pre3)
> > I'm trying to use the CELL driver to save d.his images. I set the
> > environment variables for GRASS_HEIGHT=4000 and GRASS_WIDTH=6000. When
I
> > run "d.mon start=CELL" I get the following error:
> > Segmentation Fault - core dumped
> > No socket to connect to for monitor <CELL>.
> > Problem delecting CELL. Will try once more
> > The CELL driver is present in $GISBASE/driver and I ran
> > $GISBASE/dev/create_fifos.sh. Any suggestions?
> > Thanks.
