[GRASSLIST:4037] Postgres and GRASS connection
John Dougherty
jwd at softcom.net
Fri Jul 5 21:52:43 EDT 2002
I am trying to use pg.in.dbf to bring some dbf files into postgres for use
with GRASS 5.0pre5. Postmaster is up and there are no problems connecting
directly from a console terminal. Postgresql and GRASS are both running on
the same system. I am running SuSE 8.0
I get the following error:
GRASS:~/Incoming/VECT > g.select.pg host=draco.local database=soils
Error: select Postgres:could not connect to server: Connection refused
Is the server running on host draco.local and accepting
TCP/IP connections on port 5432?
Thanks,
John Dougherty
