[GRASSLIST:4139] RE: raster import help
JGillette at rfmd.com
Tue Jul 23 16:39:58 EDT 2002
Erase the first line:
-90.000000 90.000000 .000000 360.000000 .250000 .250000
Add the following header to the file:
north: 90.125
south: -90.125
east: 360.125
west: -.125
rows: 721
cols: 1441
Import as x,y, then change the region setting to knock off
the top, bottom, left and right rows and columns. Export to ASCII,
add new header for lat/log and re-import. This is necessary
because I don't think Grass will like a lat/log region with the
given parameters. (i.e. Lon<0 and >360, etc.)
This necessary because Grass dimensions its "squares" or "cells"
by the corners.
0
| + |- +90 upper left cell has corner at -.125, +90.125
| | (based on 15min = .25deg spacing)
+---+ (721 rows = 180 X 4 + 1, 1441 cols =
360 X 4 +1 )
I got the data imported into an X, Y location with the above header.
John
> -----Original Message-----
> From: Kevin Slover [mailto:Kevin.Slover at noaa.gov]
> Sent: Tuesday, July 23, 2002 11:32 AM
> To: grass-list
> Subject: [GRASSLIST:4129] raster import help
> I am working with data that uses the WGS84 geoid. I am needed to
> convert this to MSL using, from what I have read, the EGM96 grid. I
> have downloaded the grid from NIMA, and am trying to figure out how to
> import this into GRASS.
> The grid is set up with 1st line being the header file, specifying N/S
> E/W and spacing. Then the data. Any thoughts, ideas on how
> to get this
> in. I tried r.in.gdal, but it says that the format cannot be
> recognized.
> Also, just to be safe, am I going about this the right way?? I am
> thinking about creating the grid, then using r.mapcalc to compute MSL.
> Any thoughts on this??
> Thanks...
> LTJG Kevin Slover, NOAA
> GIS Specialist/Oceanographer
> NOAA/TPC/TSB/Storm Surge Unit
> 11691 SW 17th Street
> Miami FL 33165
> W (305) 229-4456
