[GRASSLIST:4163] re:r.answers
andres javier garcia garcia
andresjavier.garcia at wanadoo.es
Fri Jul 26 11:01:08 EDT 2002
Hi Markus,
as the song prays: "I wish you were here..."
Thank you very much.
But, I'm afraid that there are still more problems:
when I try to follow steps 2 or 3 (Catalogue soils, or land use), the program
can't read the maps; and the following message appears:
<reading categories in project MASK and REGION>
WARNING: Illegal raster value less than 1 found
hit RETURN to continue -->
It is the same sample data set. I've checked that the values of categories in
the maps (a.soils & a.cover) are integer (I guess this is necessary) and
greater than 1. I've even tried to change the null values to 0's but the
problem remains.
Javier
El Vie 26 Jul 2002 11:45, escribió:
> Hi Javier,
> I have fixed that. Now the menu system is visible :-)
> Find attached the modified source code (the entire src/raster/r.answer/
> directory). Or you update from CVS.
> You must recompile this part (the r.answers command).
> Good luck,
> Markus
> On Thu, Jul 25, 2002 at 07:27:23PM +0200, javier garcia wrote:
> > Markus,
> > thanks for the offer.
> > My own data are rather big; so before attempting to use them (with the
> > subsequent adaptation of data), we are checking the available options.
> > I think that answers could be a good option because it allows distributed
> > rain data, uses Green &Ampt for infiltration, and other reasons...
> > But, first of all, I'm trying it with the simple data that come along
> > with the source code of grass.
> > Anyway, I send you the simple data set, and the steps followed:
> > grass5>r.answers
> > I choose 1. for creating a new proyect;
> > I give the name of a new proyect, by example 'sample3';
> > I give the name of a raster file to be the mask for the project, that is
> > 'a.wshd'.
> > After this, the screen appears empty with the cursor (as a rectangle)
> > fixed in the upper left corner (the beginning of
> > my unhappyness).
> > Now, if I press Return, it goes back to the first menu; and if I try to
> > began again, now here comes the beginning or the
> > fireworks.
> > I've find out that, if I write a number when the rectangle appears, and
> > press return, the program continues, but at
> > last, there is always a step where it blocks.
> > Regards
> > Javier Garcia
