[GRASSLIST:4164] m.in.e00 problem?
Jeff D. Hamann
jeff_hamann at hamanndonald.com
Fri Jul 26 11:33:14 EDT 2002
I've been trying to import some e00 files using the following step....
Mapset <PERMANENT> in Location <jackson-stp>
GRASS-GRID > m.in.e00 input=b20.e00 action=raster verbose=3
GRASS-GRID > d.mon start=x0
using default visual which is TrueColor
ncolors: 65536
Graphics driver [x0] started
GRASS-GRID > r.colors map=b20 color=grey
Color table for [b20] set to grey
GRASS-GRID > d.rast b20
100%
and the resulting image is all white...
the r.rast function returns
GRASS-GRID > r.info b20
| Layer: b20 Date: Fri Jul 26 08:14:19 2002 |
| Mapset: PERMANENT Login of Creator: hamannj |
| DataBase: /usr/home/hamannj/projects/jackson/grassdata |
| Title: ( b20 ) |
| Type of Map: raster Number of Categories: 255 |
| Data Type: CELL |
| Rows: 2751 |
| Columns: 3528 |
| Total Cells: 9705528 |
| Projection: State Plane (zone 0) |
| N: 120498.70412715 S: 37936.60595648 Res: 30.01166782 |
| E: 1367616.71679898 W: 1261735.55273279 Res: 30.01166782 |
| Range of data: min = -2147483647 max = 255 |
| Data Source: |
| Data Description: |
| generated by m.in.e00 |
which doesn't seem to be correct as the minimum value is a very large
negative number. This is a grid that was imported from a landsat7 tif image
(i would try to import it directly into grass itself but I'm having problems
with gdal on my freebsd machine right now and need to do a bunch of port
upgrades...
Is there some step I am leaving out here?
Thanks,
Jeff.
