[GRASSLIST:4167] reclass a grid with its grid-numbers
Stephan Holl
sholl at gmx.net
Sun Jul 28 09:23:11 EDT 2002
Dear GRASS-Gurus,
I would like to create a raster-map, where each pixel contains its
pixel-number as category-value.
the rows and columns are set by the region.
the pixels should be ordered in the same order as r.stats -1 does, so
that each pixel is treated as a unique value.
This value would be identical with a field in my pg-database.
So I could use d.rast.pg to pull out recalculated maps out of postgres.
Actually I am not sure, how I can create this kind of map.
Perhaps some of you could give me a hint....
cheers
stephan
Linux: the operating system with a CLUE...
Command Line User Environment.
Stephan Holl
GnuPG Key-ID: 11946A09
ICQ# 117277975
