[GRASSLIST:4180] Addition to "redirecting v.what results..."
    Andrew
    13098322 at sun.ac.za
    Tue Jul 30 17:21:56 EDT 2002
Sorry, I forgot to specify that the result is redirected to file if
batch-grass.sh is run on the command line, but I get the errors when
batch-grass is run from another programme (Pascal).
By the way, batch-grass works fine using Exec in Pascal, the errors are
generated when I try redirect the result to file using batch-grass.
Hope that makes more sense now
Andrew
