[GRASSLIST:4186] redirecting v.what results to file using batch-grass
Andreas Heigl
a.heigl at web.de
Wed Jul 31 08:11:25 EDT 2002
As far as I understand the problem you are programming a routine in pascal that uses functions of grass.
i'm not in to pascal, but it should be possible to store the results of your "Exec"-command into a variable (like $var=Exec'your_desired_command'.
if that is possible, then it should be possible to transfer the content of your variable $var to a text- or whatever-you-like-file.
wouldn't that work?
Andreas Heigl
______________________________________________________________________________
WEB.DE MyPage - Ohne Computerkenntnisse in nur 5 Minuten online! Alles
inklusive! Kinderleicht! http://www.das.ist.aber.ne.lustige.sache.ms/
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020731/aa9e4291/smime.bin
