[GRASSLIST:3844] Re: Export DEM?
Glynn Clements glynn.clements at virgin.net
Thu Jun 6 23:58:52 EDT 2002
Daniel Victoria wrote:
> I'm trying to export a grass DEM into ERDAS or
> ARC/INFO but the problem is that if I try to create an
> ascii grid I get a 2.0 Gb file because of the
> resolution and when I try to export as a binary file
> (tiff, bil, img) it exports as an image with pixel
> color values and not elevation values.
You could try r.out.bin.
Most image formats (TIFF, PPM, PNG, ...) are limited to 8-bit values,
which probably isn't sufficient for a DEM.
Glynn Clements <glynn.clements at virgin.net>
