[GRASSLIST:3854] Re: r.flowmd
Markus Neteler
neteler at itc.it
Tue Jun 11 04:56:54 EDT 2002
On Tue, Jun 11, 2002 at 11:48:15AM +0300, orkun wrote:
> after entering this command: r.flowmd elevin=f28elv_cat aspin=f28asp
> flout=fl1
> grass gives :"input files resolution differs from current region resolution"
> how can ý solve the problem ?
You have to set the current region resolution to that of the input maps:
g.region rast=f28elv_cat -p
r.flowmd elevin=f28elv_cat aspin=f28asp flout=fl1
Then it should work.
Regards,
Markus
> kind regards
> Ahmet Temiz
> Geological Engineer
> General Directorate
> of Disaster Affairs
> TURKEY
> ______________________________________
> Scanned and protected by Inflex
> http://pldaniels.com/inflex
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
