[GRASSLIST:3896] Re: Projection and m.in.e00
Ben Logan
ben at wblogan.net
Mon Jun 17 08:18:02 EDT 2002
On Sun, Jun 16, 2002 at 09:14:33AM -0700, Kristopher Hein wrote:
> I opened the E00 file, converted it to an arc binary coverage (the e00 file
> is compressed) and checked out the prj.adf file which is an ascii file
> describing the dataset's projection. It is not Lat Long, but rather an
> Albers projection. More specifically the parameters are:
> You would need to create a location with this projection and then re-project
> it to Lat Long, or what ever projection you need.
> Hope this helps!
Very much so! I did as you say, and was able to import the data with
no problems. It helps to use the correct projection, huh. :)
Thank you very much,
Ben
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
If happiness is in your destiny, you need not be in a hurry.
-- Chinese proverb
