[GRASSLIST:3917] 3D site file and NVIZ
Paul Hasenohr
phasenohr at cls.fr
Thu Jun 20 04:32:08 EDT 2002
Hello,
I try to display a 3D site file within NVIZ and it doesn't work (nviz
crashes during startup).
Here are the first ten lines of my 3D site file:
name|planeur
desc|s.in.ascii sites=planeur input=/home/hasenohr/data/grass/planeur.txt
fs=tab
0:36:49.68E|43:06:25.74N|408|#1
0:36:49.259999E|43:06:25.980012N|408|#2
0:36:53.759999E|43:06:22.799988N|409|#3
0:36:55.199999E|43:06:23.280012N|409|#4
0:36:58.920001E|43:06:24.360012N|409|#5
0:37:05.400001E|43:06:26.039988N|409|#6
0:37:15.840001E|43:06:28.98N|413|#7
0:37:19.620001E|43:06:29.999988N|417|#8
And below is the error message I get.
Is there a bug in nviz or is there a problem in the structure of my site file ?
Can I convert this site file as a 3D vector file and display it in nviz for
grass5.0pre4 or grass5.1 ?
Thanks for your help.
Paul Hasenohr
CLS
Site dim: 3
Sites file planeur at hasenohr loaded.
Adding panels from
/home/hasenohr/data/grass/grass541/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
info widget made
panel area made
file menu made
Help menu made
disabled made
Nv_mkPanelMenu 1
Nv_mkPanelMenu 2 0
Nv_mkPanelMenu 2 1
Error in startup script: divide by zero
while executing
"expr $val/floor($val/$res)"
(procedure "Nv_floatscaleCallback" line 79)
invoked from within
"Nv_floatscaleCallback $S b 0 $cmd $curr"
(procedure "Nv_mkFloatScale" line 44)
invoked from within
"Nv_mkFloatScale $tmp.sitesize h "site size" $longdim 0 $size change_site_size
2"
(procedure "mksitePanel" line 71)
invoked from within
"mk$name\Panel $path"
(procedure "Nv_force_panel" line 10)
invoked from within
"Nv_force_panel $i"
(procedure "Nv_mkPanelMenu" line 12)
invoked from within
"Nv_mkPanelMenu $Nv_(AREA).menu.panel"
(procedure "Nv_makeGUI" line 77)
invoked from within
"Nv_makeGUI .top"
(file
"/home/hasenohr/data/grass/grass541/grass5/etc/nviz2.2/scripts/nviz2.2
_script" line 660)
child process exited abnormally
while executing
"exec /home/hasenohr/data/grass/grass541/grass5/etc/nviz2.2/NVWISH2.2 -f
/home/h
asenohr/data/grass/grass541/grass5/etc/nviz2.2/scripts/nviz2.2_script -..."
("eval" body line 1)
invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scri
pts/nviz2.2_script -name NVIZ >&@stdout"
invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scrip
ts/nviz2.2_script -name NVIZ >&@stdo..."
(file "/home/hasenohr/data/grass/grass541/grass5/bin/nviz" line 16)
Mapset <hasenohr> in Location <planeur>
GRASS-GRID >
