[GRASSLIST:3972] r.in.gdal segmentation fault
Scott Holmes
scottholmes at sbcglobal.net
Thu Jun 27 16:35:18 EDT 2002
I had earlier thought this was occurring because of a bad compile of
gdal. This may or may not have contributed, but I now have freshly
compiled gdal and proj.4 both straight from their respective CVS
repositories. I am running Red Hat 7.2. After recompiling both gdal
and proj.4 I did a make distclean, configure and make on my grass code
(also from the CVS repository).
I still get a segmentation fault. Here is output from gdalinfo on what
I am attempting to import:
[scott at gandalf LACO]$ /web/GRASS/gdal/apps/gdalinfo 9978CATD.DDF
Driver: SDTS/SDTS Raster
Size is 1165, 1400
Coordinate System is:
PROJCS["UTM Zone 11, Northern Hemisphere",
GEOGCS["NAD27",
DATUM["North_American_Datum_1927",
SPHEROID["Clarke 1866",6378206.4,294.978698213898,
AUTHORITY["EPSG",7008]],
TOWGS84[-3,142,183,0,0,0,0],
AUTHORITY["EPSG",6267]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG",8901]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG",9108]],
AXIS["Lat","NORTH"],
AXIS["Long","EAST"],
AUTHORITY["EPSG",4267]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-117],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0]]
Origin = (385065.000000,3818115.000000)
Pixel Size = (10.000000,-10.000000)
Corner Coordinates:
Upper Left ( 385065.000, 3818115.000) (118d15'6.86"W, 34d30'0.08"N)
Lower Left ( 385065.000, 3804115.000) (118d15'0.09"W, 34d22'25.66"N)
Upper Right ( 396715.000, 3818115.000) (118d 7'30.12"W, 34d30'4.52"N)
Lower Right ( 396715.000, 3804115.000) (118d 7'24.04"W, 34d22'30.08"N)
Center ( 390890.000, 3811115.000) (118d11'15.28"W, 34d26'15.15"N)
Band 1 Block=1165x1 Type=Float32, ColorInterp=Undefined
NoData Value=-32766
Unit Type: m
Any help and/or suggestions appreciated...
Scott Holmes http://sholmes.ws
http://pages.sbcglobal.net/scottholmes
Independent Programmer/Analyst Passport 4GL
PHP HTML Composer PostgreSQL Informix 4GL, SQL
There are more things in heaven and earth, Horatio,
than are dreamt of in your philosophy
