[GRASSLIST:3283] Re: Topmodel parameter file
Wouter Buytaert wouter.buytaert at yucom.be
Mon Mar 4 09:54:40 EST 2002
>  The TOPMODEL code is very good and topinx has the multiple flow
> algorithm
>  which works nicely on hillslopes (too bad that you cannot get the
> upslope
>  area too from it), so it would be nice if somebody could take it, add
>  additional useful outputs and write decent manual.
>  Perhaps we find someone to write an improved manual page including an
>  example (eventually based on the parameter files in the source code)?
Well, if I can get it working, it will be a pleasure to write an
improved manual. However, until now, there are some major problems I
encounter:
- A "topographic index statistics file" is necessary as input. However,
the original TOPMODEL program doesn't need such a file. So I really
don't know what it would be.
- In my Mac OS X pre3 version, the r.water.outlet command is missing,
necessary to create a basin map. Did it disappear in the recent version,
or is it just a flaw in the precompiled macOS X version?
regards,
Wouter
