[GRASSLIST:3287] exporting grass file into ArcInfo format
Dipendra Raj Subedi
drsubedi at yahoo.com
Mon Mar 4 17:35:46 EST 2002
As a very novice guy in GRASS, I am in trouble with
converting grassfile format into ArcInfo format. I
have a file coastline.xyz that is using by grass
currently. I am in need to use this in arcinfo too. I
tried converting using r.out.ascii and r.out.arc
commands. It is giving warning as "Unable to open
raster map [coastline.xyz] in mapset [PERMANENT]."
First of all, I am not sure in which directory I have
to keep the file abc.xyz so that I can issue
r.out.ascii or r.out.arc command.
I have installed grass4.3 binary in linux from.
I have attached sample data here.
Thanks lot in advance.
Dipendra
__________________________________________________
Do You Yahoo!?
Yahoo! Sports - sign up for Fantasy Baseball
http://sports.yahoo.com
Type: application/octet-stream
Desc: coastline.xyz
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020304/bc14a2ec/coastline.obj
