[GRASSLIST:3296] Re: v.in.mif seg faults
David D Gray
ddgray at armadce.demon.co.uk
Tue Mar 5 21:12:14 EST 2002
Gordon Keith wrote:
> I tried import a mapinfo .mif file using v.in.mif in grass5 pre1 and it
> just sementation faulted.
> Looking in the bug list it doesn't look like v.in.mif works at all.
> Is this correct?
Yes. It has had problems, at least with polygon coverages, since it was
first released about a year and a half ago. I don't understand exactly
why it has deteriorated with time, presumably it has drifted as other
parts of the system ahve been updated. I suppose it would be easy to
track down this fault, but I think there would then be too many other
issues. The decision was taken to develop it anew from scratch rather
than try to maintain the current version, so v.in.shape and v.in.mif
(others?) could share a lot of code as they are very similar in basic
structure.
This is intended to go into the stable as well as
experimental/developmental relaese of GRASS, and the preview is expected
to be available with the next snapshot release in a few weeks time.
David
