[GRASSLIST:3319] Re: v.digit
Bernhard Reiter bernhard at intevation.de
Sat Mar 9 07:36:13 EST 2002
On Sat, Mar 09, 2002 at 01:07:47PM +0100, Kalicz Peter wrote:
> > Does anybody know a way to avoid to jump from the screen and to the graphic
> > monitor with the mouse during a session in v.digit. In other words, is there
> > a way to maintain the screen active for the keyboard and the monitor active
> > for the mouse permanently ?
> I use X with Linux. I press the NumLock button if the screen is active.
> With these solution I can use the screen with the keyboard and the
> monitor with the mouse in same time during digitizing.
It is a matter of the X11 window manager, if you are using X11.
There are many X11 window managers and they behave quite differently.
Check the documentation of the one you have.
They can do this in many ways.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020309/81b50d9c/attachment.bin
