[GRASSLIST:3359] Re: r.in.gdal segmentation error in Mandrake 8.1
Eric G. Miller
egm2 at jps.net
Thu Mar 21 20:42:37 EST 2002
On Thu, Mar 21, 2002 at 01:44:10PM -0800, Jeff P. Hollenbeck wrote:
> John,
> Your problems with SDTS DEM's might be due to the format change of these
> data files by the USGS in Jan 2001. You will need an updated version of
> Sol Katz's sdts2dem code to properly convert the new sdts dems. The old
> sdts2dem will chug away with the new files but produce gibberish of about
> the right size leading you to think that all went well.
> I'm not sure if gdal handles the new sdts dems correctly yet or not.
AFAIK, yes. Shouldn't need sdts2dem at all.
Eric G. Miller <egm2 at jps.net>
