[GRASSLIST:3638] Re: Safe to use GRASS 5?
Markus Neteler neteler at itc.it
Wed May 8 03:38:56 EDT 2002
On Tue, May 07, 2002 at 09:24:44PM +0200, Bernhard Reiter wrote:
> Hello Roy,
> in general the GRASS 5 beta releases are stable enough to work with.
Hello Roy,
as an addition - many GRASS developers and more people are using GRASS 5.0
for daily production. Due to the improved development process as described
below by Bernhard lots of bugs have been identified and fixed.
Even 4.3 may (and will) contain bugs, keep that in mind.
I can recommend the latest 5.0 version to you. Note that we
plan the next release of 5.0pre4 these days.
Markus
> Note that the developmen process of GRASS has significantly changed
> from the 4 to the 5 series. GRASS is now a Free Software project
> and utilises open development mostly done by volenteers.
> These developer have taken up the massive and
> partly bloated code base of GRASS and have to cope with it.
> This takes time, but we are happy that the number of active
> developers is growing steadily.
> As with open development we try to release often.
> And we require feedback and other help to get all the bugs fixed.
> Thus if nobody tests GRASS beta releases, we might not find the
> bugs in parts non of the alpha testers uses.
> 	Bernhard
> On Tue, May 07, 2002 at 05:50:35PM +0000, Roy Sanderson wrote:
> > I notice that the GRASS website now describes GRASS 5.0 as 'supported' and
> > GRASS 4.3 as 'unsupported', whereas 4.3 had previously been described as
> > 'current stable'.  Do I take it from this that it is now safe to upgrade to
> > GRASS 5.0 pre3?  I realise with its pre3 status that it is not 100% stable,
> > and that a lot of people are working hard to remove remaining bugs.
> > However, most commercial software isn't stable when sold (or at least
> > that's my impression judging by the number of patches needed just to get it
> > running in some cases!).  So should I risk upgrading to 5.0, or await the
> > release of 'stable' in presumably 6-12 months time?
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
