[GRASSLIST:3640] Re: d.what.vect area calculation
Andrea Aime
aaime at comune.modena.it
Wed May 8 04:29:13 EDT 2002
I had some strange problems with RH 7.2 and gstat, problems that
no one could reproduce... then I upgraded the kernel and the libc
using RedHat updated rpm (downloaded from a RedHat mirror) and
now everything works fine. I guess that original rpms are seriously
broken.
Hope this helps
Best regards
Andrea Aime
marino vetuschi zuccolini wrote:
> Hello to all,
> is very frustrating to bother you with some problem like that, but
> I'm very pressed by a project report and I need one solution that I
> can't find....
> I tried to compile the pre3 version for a RH 7.2 and the problem is
> the same, also with pre-built version the problem is repeated. Both
> in UTM and geographic mapsets.
> The behaviour is totally random. In a vector file with regular
> polygons, like cartographic sheets, areas close to each other have
> values differents till one order of magnitude and sometimes clearly
> negatives.
> Any Idea? Please
> ciao
> marino
