[GRASSLIST:3646] Re: Grass on Ipaq
Jan Stankovic
stankovic at itc.it
Thu May 9 05:21:46 EDT 2002
It should work on any iPAQ with (Familiar and may be other) Linux installed.
Familiar now supports iPAQs from line 3100 to 3800.
http://www.handhelds.org/platforms.html
The only problem (not really a problem but inconvenience) may be space in
ROM - 3630 has only 16 MB ROM - if he doesn't want to reinstall GRASS after
every hard reset (caused by total discharge). But it can fit to 16 MB
together with fuly functional Linux.
Jan
----- Original Message -----
To: "Jan Stankovic" <stankovic at itc.it>
Sent: Thursday, May 09, 2002 11:10 AM
Subject: Re: [GRASSLIST:3645] Grass on Ipaq
> Hi Jan,
> do you know the answer?
> Markus
> On Thu, May 09, 2002 at 10:56:37AM +0200, michele.rocc at libero.it wrote:
> > Hi,
> > This new grass for Ipaq is a great goal,
> > may this version work on Ipaq 3630?
> > Thanks, Michele.
> Markus Neteler
> ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
> Project on Predictive Models for the Environment
> Via Sommarive, 18 - 38050 Povo (Trento), Italia
> tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
