[GRASSLIST:3649] Re: How to creat tiff word file
Eric G. Miller
egm2 at jps.net
Thu May 9 10:52:57 EDT 2002
On Thu, May 09, 2002 at 03:39:46PM +0530, Anil Kumar Bhagat wrote:
> Dear Grass user ,
> I want to import my scaned toposheet map that is in tiff
> format into the lat-log map set . It is showing following error .
> It is asking for word tiff file . The output is as following
> please help me .
> TIFF Directory at offset 0x8
> Image Width: 1272 Image Length: 1650
> Resolution: 150, 150 pixels/inch
> Bits/Sample: 8
> Compression Scheme: None
> Photometric Interpretation: RGB color
> Orientation: row 0 top, col 0 lhs
> Samples/Pixel: 3
> Rows/Strip: 2
> Planar Configuration: single image plane
> Looking for TIFF World file ... Not Found!
> WARNING: G_set_window(): Illegal latitude for North
> ERROR: couldn't set cellhd.
Try importing it into an XY location. It's using the width/height with
1 pixel E-W, N-S resolution, so the resulting numbers are out of range
for a Lat/Long location. It's an error in the program that I've
corrected in CVS a few days ago (maybe in the next release).
Eric G. Miller <egm2 at jps.net>
