[GRASSLIST:3669] Re: r.in.gdal error
Markus Neteler
neteler at itc.it
Wed May 15 09:42:44 EDT 2002
Hi amil,
you can also try to use the fla "-o" as proposed by the program
(see at bottom of your mail).
Markus
On Wed, May 15, 2002 at 04:05:19PM +0200, Radoslav Bonk wrote:
> Hi Amil,
> If you have access to ERDAS IMAGINE.
> IMAGINE has nice tool for exporting *.img files into variety of
> data formats. Export it to GRASS. That will produce "cell", "cellhd" and
> other directories. All you need is to copy the files in your $GISDBASE
> structure. Unfortunately Imagine 8.4 could not export *.img files into
> GRASS floating point rasters. I am not sure about Imagine 8.5.
> Hope this helps,
> -Rado Bonk
> On Wed, May 15, 2002 at 09:02:53AM -0400, Russell Nelson wrote:
> Anil Kumar Bhagat writes:
> > Dear Grass users,
> > I am using grass5.0.0pre2 and gdal-1.1.5. I want to
> > import ERDAS (.img) raster file into my lat-long Location .When I use
> > r.in.gdal to import ERDAS (.img) raster file, it gives the fillowing ERROR
> > It work fine with X-Y Location but I want to import in lat-lon location.
