[GRASSLIST:3708] Re: help ASCII
Kevin Slover kjslover at nhc.noaa.gov
Wed May 22 11:13:21 EDT 2002
If the file is in xyz format, then you can use s.in.ascii to import the data
into sites format.  Then, there are a variety of ways to create the raster
image, s.to.rast, s.surf.rast, etc.  The easiest and quickest is s.to.rast.
Good luck...
christian.ayala at macosa.com wrote:
> Hello to all I have a file in format ASCII and desire to transform to raster
> that steps I must follow and that I must assure that the file has so that
> ningun is not had error at the moment of the conversion.
> Thanks
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
