[GRASSLIST:3722] e00 to vect to rast to xyz. Ug!
DeTracey, Brendan deTraceyB at mar.dfo-mpo.gc.ca
Wed May 22 14:15:06 EDT 2002
Hello,
I have performed the following steps on an e00 arc/info export file.
1) m.in.e00
2) v.support
3) renamed desired dig_cat file
4) v.support
5) v.reclass  (keeping the same categories. somehow this labels the
categories)
6) v.support
7) v.to.rast
When I d.what.vect/rast the maps they report the category number(139) and
the attribute string  e.g.:
2722558.07306985(E) 1927619.33955939(N)
ec_010305 in EastCoast  (139)9+_3_6_1_ at _@_7_5_4_ at _@_4_5_4_ at _@_@
When I d.legend the raster map the legend is labelled only with the category
numbers. I can't get it to label with the attribute string.
Similary r.out.xyz outputs the category numbers as the cell data.
Using r.stat -1gl also outputs the category numbers as the cell data.
How do I non-interactively get GRASS to treat the attribute strings as the
cell data
so I can use r.out.xyz on it?
Ug!
Thanks,
Brendan
Excerpts of reports of the data follow.
v.report yields:
|                         VECTOR MAP CATEGORY REPORT
|LOCATION: Cis_e00                                    Fri May 17
12:10:072002 |
|          north:        3434055    east:    4176498.25
|WINDOW    south:      821565.25    west:     1458479.5
|          res:   10009.53927203    res:  9992.71599265
|MAP:          ec_010305 in EastCoast
|                      Category Information
square|
|  #|description|
kilometers|
|  2| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
.|1,518,664|
|  3| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .|284,728|
|  4|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . .|7366|
|  5|6_3_2_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . .|14,502|
|  6|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . .|9745|
|  7|7_2_4_1_ at _7._1._7_5_@_ at _3_3_3_@_ at _@. . . . . . . . . . . . . .|7085|
|  8|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . .|10,881|
r.report yields:
|                         RASTER MAP CATEGORY REPORT
|LOCATION: Cis_e00                                    Fri May 17 12:11:37
2002|
|REGION    south:      821565.25    west:     1458479.5
|MASK:none
|MAP: ec_010305.egg_attr (ec_010305 in EastCoast)
|cell|
|  #|description|
count|
|  2| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
.|15186|
|  3| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
|2849|
|  4|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . . . . |70|
|  5|6_3_2_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . . . .
|144|
|  6|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . . . .
|102|
|  7|7_2_4_1_ at _7._1._7_5_@_ at _3_3_3_@_ at _@. . . . . . . . . . . . . . . . |70|
|  8|6_2_3_1_ at _7._1._7_5_@_ at _@_ at _@_ at _@_~9+. . . . . . . . . . . . . . .
|109|
Brendan DeTracey
VS 332
Bedford Institute of Oceanography
(902) 426-1591 : Office
(902) 426-6927 : Fax
DeTraceyB at mar.dfo-mpo.gc.ca
