[GRASSLIST:3751] help for s.voronoi
ffan at hawaii.edu
ffan at hawaii.edu
Fri May 24 20:15:55 EDT 2002
Hello,
I am using s.voronoi to draw Voronoi diagram. After I use it and get
a vect file, I use v.support before convertint the vect file to raster
file.
But when I run v.support, it shows:
WARNING: area 3 label: 3 matched another label: 5.
WARNING: area 3 label: 5 matched another label: 8.
I displayed the resultant vect file and found some lines didn't come
out.
Does anyone know what is the problem when I use s.voronoi? Thank you
in advance for your kind help.
Fengxian Fan
