[GRASSLIST:3775] Re: d.zoom revisited
Markus Neteler
neteler at itc.it
Tue May 28 12:37:59 EDT 2002
On Tue, May 28, 2002 at 09:06:36AM -0400, Kevin Slover wrote:
> Markus,
> thanks for the help so far. However, I have not been able to get
> d.zoom to work with a vector file only. It is probably user error, and
> I just wanted to make sure that I am going through the proper steps...
> I downloaded the latest tarball from CVS (both from grass5/source and
> snapshot experimental), untarred etc. I then went into
> src/display/d.zoom and ran gmake5. Afterwhich, ran gmakelinks5 -i. So
> far so good??
sounds good.
> I started up tcltkgrass and openned my vector file (shoreline.vect) and
> tried to zoom. This time at least it did not bark at me for not having
> a raster open. However, when zooming, I get the blank screen. Now, to
> add a little spice, when using default (having no buttons selected from
> d.zoom tcl menu), it allows me to zoom (though unsuccesful). When
> selecting zoom/unzoom button, it says that action not a valid parameter.
Yes - the tcltkgrass menu entry for d.zoom was outdated. I have fixed
that two days ago.
cd src/tcltkgrass
cvs login
password: grass
cvs up -dP
gmake5 -i
restart GRASS. Then it should work (d.zoom on cmd line already does
for you).
You have reached 99% already :-)
Good luck for the remaining 1%.
Markus
