[GRASSLIST:3780] Re: help v.to.rast
Anil Kumar Bhagat anil at ces.iisc.ernet.in
Wed May 29 01:46:26 EDT 2002
Please ,try to  label you vector map.
run <v.digit> module and give your vector file name . If it is contour or
any line give its value . and then do <v.to.rast> . I am not very sure
about the correct methods . But I have done like this .
Good Luck
On Tue, 28 May 2002 christian.ayala at macosa.com wrote:
> Hello to all!
> Make following steps
> 1) I obtained a map vector from a file dxf v.in.dxf.... v.support....
> g.region vect =.....
> d.vect....
> 2) soon I obtained map to raster to him using v.to.rast input=mapx
> output=mapy
> 3) soon desire to visualize the map in a the monitor and not visuzliza
> nothing, I put g.region rast=mapy and nothing in the monitor is seen either.
> How can solve this problem or that steps for obtaining raster is due to
> follow to visualize the map in the monitor correctly. ?
> Thanks
Anil Kumar Bhagat
( Project Asst. )
Center For Ecological Science ,
Indian Institute Of Science Banglore,
Banglore .
Phone : 3600985 ,3092506 ext-213
