[GRASSLIST:3811] Re: Compilation error Grass5pre4 on RH6.2
Glynn Clements glynn.clements at virgin.net
Fri May 31 10:31:59 EDT 2002
I.T.H. Deyzel wrote:
> I've compiled the pre4 source code distribution on Redhat 6.2. I've never had
> any problems doing this in the past, but this time I ran into a cliché.
> Whilst compiling lib gis bails out, complaining about a missing file. This
> causes all modules to fail.
> gisinit.c:15: version.h: No such file or directory
> make[1]: *** [OBJ.i686-pc-linux-gnu/gisinit.o] Error 1
> make[1]: Leaving directory `/opt/src/grass5src/grass5.0.0pre4/src/libes/gis'
> GISGEN failure at STEP: src/libes/gis
> I easily rectified it with a "dummy" version file and libgis compiled OK. Just
> thought someone should know about it.
src/include/version.h is generated by the configure script.
> Is there a CVS fix available for the tcl/tk GUI problem of failing to close all
> monitors when quitting?
Yes.
Glynn Clements <glynn.clements at virgin.net>
