[GRASSLIST:3813] Re: interpolate rainfall - r.runoff
Markus Neteler
neteler at itc.it
Fri May 31 12:01:39 EDT 2002
On Fri, May 31, 2002 at 10:41:37AM -0500, Guillermo Felipe wrote:
> Thank you for the answers,
> > > I have no idea what G-language is.
> > Where did you find this reference?
> In the manual...
> NAME
> r.runoff (G-language) Generates an SCS curve number runoff map layer. It is
have fixed that:
G-language -> GRASS raster command
It was the old style.
> a command-line interface for generating the runoff map by the SCS method.
> SYNOPSIS
> r.runoff rf=rainfall_map cn=cn_map ro=runoff_map
It seems to be lost, even years ago:
http://op.gfz-potsdam.de/GRASS-List/Archive/msg01065.html
You will have to look for another model:
http://grass.itc.it/modelintegration.html
or elsewhere.
Good luck.
Markus
> ----- Original Message -----
> From: "Markus Neteler" <neteler at itc.it>
> To: <GRASSLIST at baylor.edu>
> Sent: Friday, May 31, 2002 3:42 AM
> Subject: [GRASSLIST:3802] Re: interpolate rainfall - r.runoff
> > On Thu, May 30, 2002 at 06:48:15PM -0600, Roger Miller wrote:
> > > On Thursday 30 May 2002 19:12, felipe wrote:
> > > > Hello list,
> > > > What is the best method to interpolate rainfall maps in GRASS and/or
> Linux?
> > > > Something how kriging....
> > > I have used gstat ( http://www.gstat.org ) to produce GRASS raster maps
> via
> > > kriging. Gstat offers a lot of capabilities, but the version I have is
> > > fairly difficult to use and behaves badly with even moderate-sized
> datasets.
> > > With luck that has been improved.
> > Another method is to use s.vol.rst if you interpolate in an area
> > with non-flat elevations (refs: [1], [2])
> > You need
> > - 3D sites of climate stations (x,y,z,attribs)
> > - 2D raster DEM
> > The interpolation is done with 3D RST (3D splines) as provided by
> > 's.vol.rst'.
> > 's.vol.rst' expects you have defined 3D region (as every other 3D module).
> > Therefore you have to run 'g3.createwind' script before 's.vol.rst'.
> > It doesn't matter that you will produce just a 2D, intersection file.
> > 's.vol.rst' asks for 3D region during the input (remember, you must have
> > 3D sites file).
> > With 'g3.setregion' you can change your vertical resolution to 3000m
> > (i.e. define only one depth layer, s.vol.rst will be happy with that).
> > The command line may be something like this:
> > s.vol.rst in=precip3d cellinp=dem500 cellout=precip.topo zmult=50
> > The resulting map 'precip.topo' is a 2D raster map containing the
> > precipitation. This precipitation was calculated internally with
> > 3D Regularized Splines with Tension (RST). The 'cellinp' method
> > extracts the precipitation values from the precipitation volume at
> > the individual elevations as stored in the 'dem500' raster map.
> > [1] Hofierka J., J. Parajka, H. Mitasova, and L. Mitas, 2002. Modeling
> > impact of terrain on precipitation using 3-D spatial interpolation.
> > Transactions in GIS, March 2002, vol. 6, no. 2, pp. 135-150(16)
> > [2] The upcoming GRASS book
> > > > I need to generate some rainfall maps to scs runoff calculation.
> > > > Where can I get the r.runoff code?
> > > > What is G-language?
> > > r.runoff was part of grass4. Documentation for r.runoff is still
> included in
> > > grass5, but I haven't been able to find the code. You may be able to
> get it
> > > from a grass4 distribution or from somewhere deep in the Grass CVS tree,
> but
> > > I can't lead you to believe that it will work with Grass5.
> > Check also:
> > r.cn help
> > Description:
> > Generates a SCS curve number map layer
> > Markus Neteler
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
