[GRASSLIST:4960] Re: Areas in dig_att
Michael Ash
mash at econs.umass.edu
Fri Nov 15 02:30:05 EST 2002
> > I'm looking at the dig_att file of my subbasins map and I can see the
> > coordinates (of the area centroid?), if it is an arc or line and the
> > cat.number.
> > Issue 1: How do I get the areas of the subbasins into the
> > attribute table?
> You don't. But maybe you can turn them into a category file
> (dig_att/<name>). The format is documented in the programming manual,
> but mostly is just lines of "<category number> : <some text>".
SHOULD THE ABOVE READ "turn them into a category file (dig_cats/<name>)" ?
Michael
