[GRASSLIST:5036] Re: GRASS 5.0; NVIZ visualation tool: problems starting under SuSE 8.1
Markus Neteler
neteler at itc.it
Fri Nov 22 09:30:53 EST 2002
below problem is fixed in CVS. It will appear in 5.0.1.
You can also modify the code yourself, see
/usr/local/grass5/etc/nviz2.2/scripts/widgets.tcl
search round line 204 for
if {$val < $res } {
and change it to
if {$val < $res || $res == 0} {
This may help,
Markus
On Thu, Nov 21, 2002 at 10:30:39PM +0100, Lars Forseth wrote:
> Hi!
> I have just uppgraded my linux installation to SuSE 8.1.
> I have also installed GRASS (GIS) 5.0. This went well; and the basic tcl/tk
> interfrace (tcltkgrass) startet. When I try to run NVIZ, the 3d vizualation
> tool, it fails. A note here; I have created the usual symlinks in libtk/tcl;
> i.e ln -sf /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0 and
> /usr/lib/libtk8.4.so /usr/lib/libtk.so.0.
> Mesa is installed; and gears is running.
> Below is the output from the NVIZ program (run from tcltkgrass). Does anyone
> have any idea why it crashes?
> Regards
> lars Forseth
> Loading Data
> Update elev null mask
> Loading Data
> translating colors
> Site dim: 2
> Sites file bugsites loaded.
> Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
> Nv_(panels)
> toplevel made
> child killed: segmentation violation
> while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
> cripts/nviz2.2_script el=elevation.dem si=bugsites -name NVIZ >&@stdout"
> ("eval" body line 1)
> invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
> $env(GISBASE)/etc/nviz2.2/scri
> pts/nviz2.2_script $argv -name NVIZ >&@stdout"
> invoked from within
> "if {$argv == ""} {
> #no arguments
> $env(GISBASE)/etc/nviz2.2/scrip
> ts/nviz2.2_script -name NVIZ >&@stdo..."
> (file "/usr/local/grass5/bin/nviz" line 16)
> Finished - press RETURN or ENTER to continue
> Lars Forseth
> GIS/IT Kaupang-undersøkelsen
> http://folk.uio.no/forseth
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591) http://mpa.itc.it
