[GRASSLIST:5071] RE: Grass to Postgres
Juanse
georef at tie.cl
Mon Nov 25 21:00:35 EST 2002
Right, it is actually not that simple to read a postgresql/postgis layer from grass5.1
after reading and trying, trying and reading, it seem that postgis file structure is not suited for grass5.1 postgrass directly reading.
In fmrt files i am ask to provide several fields for grass to be able to find the geometry and category data.
Postgis stores in one column in my case wkb_geometry, a string identifying at the same type the SRID, the geometry type and the actual geometry in wkb, with a constrain at the end that tell pgsql how this string is constructed (Am i right?).
Has anyone build a protocol or sql sentence to prepare a postgis table for the grass requiered format: ie separate geometry from category with the same ID on both tables, and in the geometry table separate the geometry from the geometry type?
which geometry type are allowed in Grass, i have an int4 from >0 to < 5, which are those? which int is equivalente to point, which to line, which to polyline, which to area and so on?
Juanse
temuko-Chile
----- Original Message -----
To: Richard Greenwood
Cc: postgis-users at postgis.refractions.net ; GRASSList at baylor.edu
Sent: Monday, November 25, 2002 9:04 PM
Subject: [GRASSLIST:5069] RE: Grass to Postgres
I have pass the first wall. I need some Grass help.
what is the meaning of Location, mapset and database.
I sort get that they are related to the actual path where the data is? Am i correct?
I have made the following dir structure
Inside Home i have created Mapa dir, and inside it a vector dir and inside it a rio dir
/home
/home/mapa
/home/mapa/vector
/home/mapa/vector/rio
inside rio i have make two files:
head (with nothing in it)
and frmt with
FORMAT:postgis
HOST:192.168.0.1
PORT:5432
DATABASE:ejercicio
USER:postgres
PASSWORD:xxxx
GEOM_TABLE:rios
CAT_TABLE:rios
#GEOM_ID:
#GEOM_TYPE:
#GEOM_GEOM:
#CAT_ID:
#CAT_FIELD:
#CAT_CAT:
rios is a NTAM table in ejercicio. I am using it again for categories. Is that all right or i have to separate geometry from categories in pgsql/gis?
after running grass51 i have set
Mapset: rio
database: /home/mapa/
<esc><enter>
welcome to grass 5.1
bla bla bla
GRASS:/home/map/vector/rio> d.mon start=x0
d.mon: error while lodaing shared libraries: libpd.so: cannot open shared object file: No such file or directory.
where do i have the mistake?
Do I need that pqsql library installed in the client machine? why?
Is is already installed on the pgsql server.
Do i need to make this path structure by hand for each layer i want to use in grass eventhough they are all stored in the same pgsql/GIS database?
Juanse
temuko-Chile
To: Juanse
Sent: Monday, November 25, 2002 8:16 PM
Subject: Re: Grass to Postgres
It is no bother at all, but I'm afraid that I have not tried connecting to PostGIS from GRASS. I have only used PostGIS with MapServer. Keep trying on the GRASS list and maybe try asking the Refractions guys for help. And please post your finding because I would like to give it a try if I ever find some time.
Best regards,
Rich
At 08:09 PM 11/25/2002 -0300, you wrote:
Hi Richard
Sorry to bother directly but seem that this Grass to Postgres is to much for a new comer.
have you tried it yet?
can i bother with some questions?
Having the data already in postgreSQL/PostGIS, how to read it with Grass?
I am making the head and frmt, but have question as to the definition of various entries, the same applies for location, mapset and database.
Juanse
temuko-Chile
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.417 / Virus Database: 233 - Release Date: 08/11/02
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich at GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20021125/97241a1d/attachment.html
