[GRASSLIST:4873] DTM from a dxf-3D file
    Andrea Mamusa
    amamusa at tiscalinet.it
    Fri Nov  1 12:41:29 EST 2002
Thanks to all for the answers to my previous question (nviz libpq.so error):
Now nviz run correctly.
I need to create a DTM starting from a dxf-3D file with contour lines.
I try to import with command v.in.dxf and v.support to rebuild topology and v.to rast but the
the problem is that when i convert the vector contour map (.DFX) to raster i get a raster
file containing patches or points of different colors rather then the actual contour lines
To run v.surf.rst program caused a sudden crash system. Is this method wrong?
Can anyone please tell me which are the correct steps to create the DTM raster map?
Thanks,
Andrea Mamusa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20021101/6968906a/attachment.html
