[GRASSLIST:4896] RE: Grass Installation
Glynn Clements
glynn.clements at virgin.net
Wed Nov 6 15:39:20 EST 2002
Dan Gelinas wrote:
> now I get this message: failed to find FFTW includes.
> -I searched for FFTW on my box with no results. :(
> -I also searched the configure script for hints.
> Can anyone give me a hint as to what this does and to what I need to
> get it working?
FFTW is a library for performing fast-Fourier transforms, and is
available from www.fftw.org. It is used by i.fft, i.zc, i.shape and
r.surf.fractal; if you don't need any of those programs, then you can
disable it with configure's "--without-fftw" switch.
Information regarding optional libraries can be obtained from the
REQUIREMENTS.html file, which resides in the top-level directory of
the GRASS source tree.
Glynn Clements <glynn.clements at virgin.net>
