[GRASSLIST:4899] reversing cat order for d.legend ?
H. Bowman
ihatejunkyabastards at yahoo.com
Thu Nov 7 07:33:21 EST 2002
Hello all,
I would like to display a legend box showing how elevation relates to map
color for a raster DEM.
d.legend works, but the lowest elevations are at the top, and the mountain
peak elevations are at at the bottom of the legend. Is there a way to
reverse this? r.report displays smallest values first, so I suppose
d.legend follows from that?
Trying to be sneaky and making the first corner not the top left, and the
second corner above the first doesn't seem to do the right thing at all.
It looks better if I make a horizontal legend, but that doesn't look quite
right below to my tall, thin display.
Should I give up and just flip it in Gimp and add then re-add the text
labels by hand?
Also with regards to d.legend, any suggestions for defining the bounds and
output format of the text labels? lines= and thin= don't seem to make any
difference (because floating point raster?), and outputting 6 digits
beyond the decimal is a bit excessive for my application. I don't mind
manually placing text, but I would like to have the bounds be nice whole
numbers a bit larger than my range. I'd rather not introduce false data
points to trick the range.
Should I be looking at printf("%.0f",foo) etc and a recompile...?
and modify the code to grab the range from my custom color table?
thanks
