[GRASSLIST:4676] Re: Outputing values of neighboring cells in a DIFFERENT layer
Glynn Clements glynn.clements at virgin.net
Mon Oct 7 13:36:16 EDT 2002
Jason Horn wrote:
> I'm looking for a little advice.  I need to output some cell values by
> examining two raster layers.  I need to know the values of neighboring
> cells (very much like what r.neighbors does).  However, rather that
> getting the values of the neighboring cells in the same layer, I need
> the values of the neighboring cells of the corresponding cell in a
> DIFFERENT layer.
> For example: I have two layers A and B.  I'm interested in cell (10,
> 10) in layer A.  I'd like to output the values of the neighboring
> pixels from the corresponding cell (10, 10) in layer B.  I want to do
> this for every cell that is part of a particular phenomenon in layer A.
> r.neighbors is close, but not quite it.  I need the ability to get the
> values of neighboring cells from OTHER layers.  Does anyone have any
> ideas?
I'm not entirely sure what you're doing, but it may be that you want
to run r.neighbors on B to produce C, then combine A and C in some
way.
If you can be more specific about the task, I may be able to be more
specific about the solution.
Glynn Clements <glynn.clements at virgin.net>
